2013年12月10日,致力于亚太地区市场的领先电子元器件分销商---大联大控股宣布,其旗下世平集团推出基于Fairchild和NXP产品的针对小家电电机控制市场的电源解决方案。该解决方案具体包括Fairchild FSL156和FSL306LRN完整电源解决方案、NXP TEA1731和TEA1721 完整电源解决方案。大联大世平集团同时宣布针对该方案提供技术支持。
Fairchild FSL156完整电源解决方案
大联大世平集团推出的Fairchild FSL156加入了Advanced Soft Burst Mode降低功耗,具有较低的操作电流(0.4mA)。另外RFF将降低EMI,内建650V SenseFET及Soft-Start :15mS,可应用于家用电器,LCDM等产品。FSL156MRIN为DIP-8,可应用于输入230VAC: 26W(Adapter) ~ 40W(Open Frame)。输入85 ~ 265Vac:20W(Adapter) ~ 30W(Adapter)。
FSL156芯片参数:
Internal Avalanche Rugged SenseFET: 650V
Precision Fixed Operating Frequency: 67kHz
No-Load 150mW at 265VAC without Bias Winding
25mW with Bias Winding for FSL206MR
30mW with Bias Winding for FSL206MRBN
No Need for Auxiliary Bias Winding
Frequency Modulation for Attenuating EMI
Line Under-Voltage Protection (LUVP)
Pulse-by-Pulse Current Limiting
Low Under-Voltage Lockout (UVLO)
Ultra-Low Operating Current: 300?A
Built-In Soft-Start and Startup Circuit
Various Protections: Overload Protection (OLP),Over-Voltage Protection (OVP), Thermal Shutdown(TSD), Abnormal Over-Current Protection (AOCP),Auto-Restart Mode for All Protections
Fairchild FSL306LRN 完整电源解决方案
大联大世平集团推出的Fairchild FSL306LRN在230Vac 输入时以及有Extemal Bias时,会展现小于25mW的超低功耗表现;在没有Extemal Bias时小于120mW,具有更低的操作电流(250uA),同时不需要加入AUX Bias Winding以节省PCB空间。该产品可应用于Buck : 3W 以内,Flyback:7W以内。此产品主要应用于家用和工业用的电源产品。
FSL306LRN 参数:
"Built-in Avalanche Rugged SenseFET: 650 V
"Fixed Operating Frequency: 50 kHz
"No-Load Power Consumption: 25 mW at 230 VAC with External Bias;120 mW at 230 VAC without External Bias
"No Need for Auxiliary Bias Winding
"Frequency Modulation for Attenuating EMIPulse-by-Pulse Current Limiting
"Ultra-Low Operating Current: 250 ?A
"Built-in Soft-Start and Startup Circuit
"Adjustable Peak Current Limit
"Built-in Transconductance (Error) Amplifier
"Various Protections: Overload Protection (OLP), Over-Voltage Protection (OVP), Feedback Open Loop Protection (FB_OLP), AOCP (Abnormal Over-Current Protection), Thermal Shutdown (TSD)
"Fixed 650 ms Restart Time for Safe Auto-Restart Mode of All Protections
